| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can show, hide, and reorder screens and views. You can also set up default views for screens in your application. The screens and views available to you are always available through the Site Map, even if their names are hidden.
You can show or hide screens.
To show or hide screens
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
Navigate to the Tab Layout view.
The Screen Tab Layout and View Tab Layout lists appear.
In the Screen Tab Layout list, select the record for the screen you want to show or hide, and do one of the following:
Clear the Hide check box to show the screen.
Select the Hide check box to hide the screen.
Note: If you hide a screen, then all the views within that screen are also hidden. |
You can show or hide views.
To show or hide views
In the Screen Tab Layout list, select the record for the screen associated with the view you want to show or hide.
The View Tab Layout list shows the views for the selected screen.
In the View Tab Layout list, select the record for the view you want to show or hide, and do one of the following:
Clear the Hide check box to show the view.
Select the Hide check box to hide the view.
You can change the order in which screens appear.
To change the order in which screens appear
In the Screen Tab Layout list, type a whole number in the Order field for each screen to define the position of that screen.
Use the number in the Order field to re-sequence the screens in ascending order. If you use the same number in the Order field for more than one screen, then the screens with the same number appear in alphabetical order.
You can change the order in which views appear.
To change the order in which views appear
In the Screen Tab Layout list, select the record for the screen for which you want to reorder views.
In the View Tab Layout list, type a whole number in the Order field for each view to define the position of that view.
Use the number in the Order field to re-sequence the views in ascending order. If you use the same number in the Order field for more than one view, then the views with the same number appear in alphabetical order.
You can set up a default view for a screen.
To set up a default view for a screen
In the Screen Tab Layout list, select the screen for which you want to set up a default view.
In the View Tab Layout list, select the Default View check box for the view you want as the default view for the screen.
