| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
After you create quick fill templates, you can change some of their properties, and you can deactivate or delete the templates. You can perform the tasks in this topic only for the quick fill templates that you create.
This topic contains information about the following:
You can rename a quick fill template.
To rename a quick fill template
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
Navigate to the Quick Fill Templates view.
The Templates list appears.
Select the template you want to rename.
In the Template Name field, type a new name for the quick fill template.
(Optional) In the Description field, change the description of the template.
You can deactivate a quick fill template.
To deactivate a quick fill template
Select the template you want to deactivate.
In the Active field, clear the check box.
The template is no longer available for selection when you create a new record from a quick fill template.
You can reactivate a quick fill template.
To reactivate a quick fill template
Select the template you want to reactivate.
In the Active field, select the check box.
The template is now available for selection when you create a new record from a quick fill template.
You can permanently delete a quick fill template.
To permanently delete a quick fill template
In the Templates list, select the quick fill template you want to delete, and then click Delete (the trash can icon).
At the confirmation dialog box, click OK.
In preconfigured applications, Quick Fill Template menu options are available for some applets, such as Activity Form Applet, and are not available for other applets, such as FS Invoice Form Applet. You can assign the Quick Fill Template menu options to other applets by adding Applet Method Menu Item objects.
To add Quick Fill Template options in an applet menu
In Siebel Tools, select the applet to which you want to add the quick fill template options.
Navigate to the Applet Method Menu Items list for the applet.
An Applet Method Menu Item defines a menu item in the applet-level menu for the parent Applet object definition. For more information about Applet Method Menu Items, contact your administrator.
In the Applet Method Menu Items list, add the records in the following table.
| Command Field Value | Menu Text Field Value |
| ApplyTemplate | Apply Template |
| SaveTemplate | Save as Template |
| NewFromTemplate | New From Template |
| NewFromLastTemplate | NewFromLastTemplate |
