| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can view and manage activities in the daily, weekly, or monthly format of your calendar. You can specify any of the calendar formats as the default format in the Calendar screen. For more information, see "Default Calendar Formats".
Note: You cannot query for activities in the calendar. |
To view calendar activities
Navigate to the Calendar screen.
The calendar appears, showing the daily calendar format.
(Optional) Click a button to change the calendar format.
For more information, see "Calendar Formats".
Place your cursor over the hyperlink for an activity description to view details about that activity.
