| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can query in a selection dialog box just as you query in a list or form. Consequently, you can search for specific information from one field or from several fields simultaneously.
To query for records in a selection dialog box
In the selection dialog box, click Query (the magnifying glass icon).
A blank row appears in the selection dialog box.
Enter your query criteria in the appropriate fields.
A wildcard is automatically assumed after text you enter in the query fields. If you search for Siebe, then all words beginning with the letters Siebe are found.
If you query a data field that has a calendar select button to display the calendar control, then you must include the date field value in quotes if you execute the query without specifying a time. For more information about entering query criteria, see "Simple Query Operators".
Click Go.
The records matching your query criteria appear.
