Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Hospitality Guide > Generating Event Checks > Process of Generating Event Checks > Generating Event ChecksOperations managers and event managers can generate an event check for a single order, or event checks for all orders in a day for a property. When an event check is generated, the following actions occur in the order:
You can navigate to the Event Checks screen to see more detail about the generated event check. You must cancel an event check before you can use the procedures in this topic to generate another event check for the same order. This task is a step in Process of Generating Event Checks. Generating an Event Check for a Single OrderTo generate an event check for a single order, follow this procedure. To generate an event check for a single order
Generating Event Checks for All Orders in a Day for a PropertyOperations managers and event managers can generate event checks for all orders in a specified day for a specified property. To generate event checks for all orders in a day for a property, follow this procedure. To generate event checks for all orders in a day for a property
About Generated Event ChecksFor each generated event check, one of the following results occurs:
The event checks are generated, and the Event Checks screen, Line Items (Guest) view appears. The detailed event check records appear in the Event Checks screen list. In each package event check record, the Package Event Check check box is selected. Meeting package elements, if any, are displayed on the Meeting Packages and Meeting Functions views. Nonfunction line items, if any, are displayed on the Non Function Line Items view. For trial event checks generated with the Trial Check button, the Status fields of the event check records are set to Trial. For event checks generated with the Open Check and Open Day buttons, the Status fields of the event check records are set to Open. The Post Date fields remain blank. The event check line items show all the applicable taxes and service charges. |
Siebel Hospitality Guide | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
