| Siebel CRM Partner Relationship Management Administration Guide Siebel Innovation Pack 2017, Rev. A E24800-01 |
![]() Previous |
![]() Next |
View PDF |
When a partner adds an item to a new shopping cart, both standard partner commerce and power partner commerce call workflows that ask whether the partner is shopping on behalf of a customer or on their own behalf.
You can turn off this functionality by deleting the following parameter:
PostAddToCartLogic = eChannelShoppingScenarios
You must delete this parameter in both the Server Administration screen and the Siebel Server.
To disable the message that asks partners who they are shopping for
Use any text editor to open the configuration file for the Siebel PRM Portal, which is the file installation directory\siebsrvr\bin\lang\scw.cfg.
In the [InfraShoppingService] section of the file, delete the following line:
Change this parameter in the Server Administration screen:
Navigate to the Server Administration screen, then the Components.
Navigate to the Component Parameters view.
In the Components list, search for eChannel Object Manager in the Name field.
In the Component Parameters list, find the parameter PostAddToCartLogic and delete it.
Restart your server.
