| Siebel CRM Partner Relationship Management Administration Guide Siebel Innovation Pack 2017, Rev. A E24800-01 |
![]() Previous |
![]() Next |
View PDF |
The standard method of removing toolbars is not used for removing the Shopping Cart toolbar from the Siebel PRM Portal.
This topic gives high-level instructions for removing this toolbar. Do this only if you are experienced at working with Siebel Tools. For more information, see Using Siebel Tools.
To remove the PRM Portal shopping cart toolbar
In Siebel Tools, navigate to:
Web Page = Page Container Partner Portal Web Page
Web Page Item = Shopping Cart
Set Inactive = TRUE.
