Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Product Administration Guide > Creating Custom Siebel Configurator User Interfaces > About Default and Custom Siebel Configurator User InterfacesYou must decide whether to use the default Siebel Configurator user interface or to design a custom user interface. The default user interface displays all the configurable items in the customizable product on a single selection page. If you create a custom interface, you can display the configurable items on multiple pages. The default user interface makes intelligent choices for UI controls based on attribute domain type and upon relationship cardinality. For example:
If you create a custom interface, you can select the control used for each configurable item, and you can create several Open UI interfaces and assign them to users based on their responsibilities and their browsers. The application decides which interface to assign to a user using the decision flow shown in Figure 4. NOTE: The default SWT file templates are documented as Applet User Properties found in Siebel Tools for the applet Cfg CX Runtime Instance Frame (JS HI). |
Siebel Product Administration Guide | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
