Siebel Remote and Replication Manager Administration Guide > Reference Materials for Siebel Remote >
Values for System Preferences
Table 34 lists values for system preferences for Siebel Remote. You specify these values in the Remote System Preferences view of the Administration - Siebel Remote screen.
Table 34. Values for System Preferences for Siebel Remote
System Preference
Default Value
Other Values
Docking Timestamp Source
Client Transaction Time
Server Database Merge Time
Enable Mobile Password Expiration
Check box contains a check mark, by default.
No check mark
Enable Mobile Password Syntax Check
No check mark
Enable Mobile Web Client Lockout
No check mark
Enable Transaction Logging
No check mark
Expiration Period
5
Positive integer greater than zero is a valid value.
Failed Login Attempts
2
Positive integer is a valid value.
Intersection Table Conflict Resolution
Merge
You can use the following values:
  • First In
  • Last In
Intersection Table Merge Rule
First In
Last In
Lockout Period
1
Merger Friendly Notification
Conflicts
  • True
  • False
Merger Transactions Commit
50
  • 10 for DB2
  • 10 for Oracle
  • 1 for Microsoft SQL Server
Minimum Number of Characters
5
Integers from 1 through 15 are valid.
Optimized Visibility Check
No check mark
Password Content
Alphanumeric Special Character
  • Alphanumeric
  • None
  • Special Character
SFM: Maximum File Attachment (KB)
100
System Conflict Resolution
Server Wins
Client Wins
Visibility Rules Per Statement
50
Not applicable.
Visibility Rules Per Statement 1
20
Not applicable.
Visibility Rules Per Statement N
1
Not applicable.
Warning Period
2
Siebel Remote and Replication Manager Administration Guide Copyright © 2017, Oracle and/or its affiliates. All rights reserved. Legal Notices.
