| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2017, Rev. A E24814-01 |
![]() Previous |
![]() Next |
View PDF |
Siebel Open UI is the most secure Siebel CRM client available and is therefore recommended if your Siebel implementation has high-security requirements. In particular, note the following about Siebel Open UI:
Siebel Open UI uses an open architecture that allows you to run Siebel Business Applications on any Web browser that is compliant with the World Wide Web Consortium (W3C) standards. Siebel Open UI also supports a number of operating systems, including Windows, Mac OS, or LINUX.
The Siebel Open UI client is compatible with many security features supported by the Web browser on which it runs.
Siebel Open UI uses only three technologies to render the client code: HTML, CSS, and JavaScript. Because of the small set of underlying technologies that are used to render the client and the absence of third-party plug-ins, Siebel Open UI provides the smallest possible attack surface.
Siebel Open UI clients enforce session security by requiring that session IDs can only be passed in session cookies. For information, see "Session Cookie".
For additional information about Siebel Open UI, see Deploying Siebel Open UI and Configuring Siebel Open UI.
Note: The procedures in this guide assume that you do not use the Tree navigation control option to access screens and views. However, you can choose to use the Tree navigation control if required. For more information about setting navigation options, see Siebel Fundamentals Guide. |
