| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2017, Rev. A E24814-01 |
![]() Previous |
![]() Next |
View PDF |
Table A-2 lists the parameters in the Enterprise Profile that relate to authentication and security. You define these parameters in the Authentication section and Security Information section under Enterprise Profiles in the Siebel Management Console.
Table A-2 Authentication and Security Parameters in the Enterprise Profile
| Parameter | Section Under Enterprise Profiles | Description |
User Name |
Authentication |
The user name. |
Password |
Authentication |
The user password. |
Authentication Profile |
Authentication |
The authentication profile for the Enterprise. |
Primary Language |
Authentication |
The primary language for the Enterprise deployment. |
Security Encryption Level or Type |
Security Information |
The level or type of security encryption. The options are:
Certificate Authority (CA) Certificate File Name |
Security Information This option appears if the Security Encryption Level or Type parameter is set to TLS 1.2. |
The name of the CA Certificate file. |
Private Key File Name |
The name of the private key file. |
Private Key File Password |
The password for the private key file. |
Enable Peer Authentication |
Select this option to enable peer authentication. |
Validate Peer Certificate |
Select this check box to validate the peer certificate. |
