| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2017, Rev. A E24814-01 |
![]() Previous |
![]() Next |
View PDF |
Table A-3 lists the parameters in the Server Profile that relate to security. You define these parameters in the Enhanced Settings - Security section under Siebel Server Profiles in the Siebel Management Console.
Table A-3 Security Parameters in the Server Profile
| Parameter | Section Under Siebel Server Profiles | Description |
Server-Specific Security Encryption Settings |
Enhanced Settings - Security |
Select this option to configure security and encryption for communications between the Siebel Server and other servers. If you do not select this option, then the settings are inherited from the Enterprise. |
Server-Specific Security Authentication Profile Assignment |
Select this option to assign an existing security adapter to this Siebel Server or to specific components. |
Security Encryption Level or Type |
Enhanced Settings - Security This option appears if you select the Server-Specific Security Encryption Settings parameter option. |
Specify the security encryption level or type. The options are:
Certificate File Name |
Enhanced Settings - Security This option appears if you select the Server-Specific Security Encryption Settings parameter option and the Security Encryption Type or Level parameter is set to TLS 1.2. |
The password for the private key file. |
Certificate Authority (CA) Certificate File Name |
Enhanced Settings - Security This option appears if you select the Server-Specific Security Encryption Settings parameter option and the Security Encryption Level or Type parameter is set to TLS 1.2. |
Select this check box to enable peer authentication. |
