| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2017, Rev. A E24814-01 |
![]() Previous |
![]() Next |
View PDF |
This topic provides information about the way in which Siebel Business Applications support the requirements of several security standards. It includes the following topics:
The Payment Card Industry (PCI) Data Security Standard (DSS) is a set of standards developed to enhance the security of credit card data in organizations that process such data. Developed by the PCI Security Standards Council, the standards are designed to prevent credit card fraud by implementing consistent data-security measures, which include requirements relating to network management, security policies and procedures, and data-access management.
PCI DSS compliance is required of all organizations that store, process, or transmit credit cardholder data. The PCI DSS currently outlines six basic principles for compliance, supported by more detailed subrequirements for compliance.
Table C-4 lists the PCI requirements and the ways in which Siebel Business Applications support these requirements.
Note: Siebel Business Applications and features do not currently meet certain audit-related PCI DSS 3.1 compliance standards. The following PCI DSS 3.1compliance standard items are not covered by Siebel audit trail:
Table C-4 Siebel Business Applications and PCI DSS Requirements
| PCI DSS Principle | PCI DSS Requirement | Siebel CRM Support for PCI DSS |
Build and maintain a secure network. |
Do the following:
Siebel Business Applications support the deployment of firewalls, reverse-proxy servers, and Network Address Translation devices to protect application data from intrusion. During the installation of Siebel Business Applications, warnings are issued if the password specified for the user ID used to start services and processes is the same as the user ID. The installer can use any user ID and password that have the appropriate privileges to perform the task it is required to perform (such as administrator privileges to start services). |
Protect cardholder data. |
Do the following:
Siebel Business Applications allow customers to encrypt sensitive information stored in the Siebel database, cardholder data, and other data transmitted across networks. |
Maintain a vulnerability management program. |
Do the following:
These requirements are customer-governance issues. Oracle recommends that you implement them. For help with security-governance issues, contact your Oracle sales representative for Oracle Advanced Customer Services to request assistance. |
Implement strong access control measures. |
Do the following:
Siebel Business Applications provide multitiered access-control mechanisms so that only those users with appropriate rights have access to the data. This control includes view-level access control and record-level access control. Each Siebel application user is assigned a login ID, a primary position, and a responsibility in the Siebel application. These security attributes provide the user with the appropriate access rights to the Siebel application. Users do not have direct access to the Siebel database; only the Siebel application has access to it. To prevent users from circumventing application-security protocols if database security is used, then Siebel user passwords can be hashed using the RSA SHA-1 algorithm. Enabling password hashing makes sure that the password used to access the Siebel database is not the same password that the user uses to access the Siebel application. In addition, using an LDAP, Single Sign-On, or custom-security adapter to access Siebel Business Applications requires that user database access is managed through a shared application credential, and not through a user ID and password. |
Regularly monitor and test networks. |
Do the following:
To maintain data continuity and monitor activity on a Siebel CRM site, you can configure Siebel Audit Trail. This feature allows you to maintain an audit trail of information that indicates when business component fields have been changed, who made the change, and what has been changed. These requirements are customer-governance issues. Oracle recommends that you implement them. For help with security governance concerns, contact your Oracle sales representative for Oracle Advanced Customer Services to request assistance. |
Maintain an information security policy. |
Maintain a policy that addresses information security. |
This requirement is a customer-governance issue. Oracle recommends that you implement it. For help with security governance concerns, contact your Oracle sales representative for Oracle Advanced Customer Services to request assistance. |
The Common Criteria for Information Technology Security Evaluation (Common Criteria) is an international technical standard that allows for security evaluations of computer products and technology. By providing an independent evaluation of a product's ability to meet specific security requirements, Common Criteria certification allows purchasers of IP products and technologies to make more informed decisions.
Siebel CRM version 7.8.2 obtained Common Criteria certification in January 2006. The security architecture of subsequent releases of Siebel CRM is unchanged from that release. The Validation Report for Siebel Business Applications Common Criteria certification is available on the Certified Products page of the Common Criteria Web site at
http://www.commoncriteriaportal.org/
For more information on Siebel CRM support for the Common Criteria standard, see 1363489.1 (Article ID) on My Oracle Support.
The United States government Federal Information Processing Standard (FIPS) 140 outlines the minimum security requirements for cryptographic modules (both hardware and software) that are used to protect sensitive information.
It is recommended that you verify that the cryptography module used in the applications in your implementation have FIPS 140-1 or FIPS 140-2 certification. The RSA BSAFE libraries used in Siebel Business Applications are FIPS 140-2 certified. Information on the standards supported by RSA BSAFE are available on the RSA BSAFE products page of the RSA Web site at
