| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2017, Rev. A E24814-01 |
![]() Previous |
![]() Next |
View PDF |
This topic lists the default port allocations used by Siebel Business Applications.
The port allocations that are assigned by default during the installation of Oracle's Siebel Business Applications for the Siebel Server and Siebel Web server are shown in Table C-5. It is recommended that you change the default ports used by these components.
Note: In a Siebel Business Applications deployment, DNS servers use User Datagram Protocol (UDP) port 53 and Kerberos defaults to port 88. |
Table C-5 Default Port Allocations for Siebel Business Applications
| Siebel Component | Port Number | Comments |
Web Server |
80 and 443 |
Port 80 is used for standard Web traffic. If encryption is implemented, then port 443 is used. |
Gateway |
2320 |
Load-balancing components use port 2320. |
Siebel Server |
2321 |
SCBroker listens on port 2321. For information on SCBroker, see Siebel System Administration Guide and Siebel Deployment Planning Guide. |
Siebel Server |
49150 and higher 49149 and lower 49152 to 49250 |
Siebel Business Applications use dynamic allocation of ports for the server-based components. Static port allocation is also supported. The dynamic port allocation starts from port number 49150 onwards. If you choose to assign static ports to the components, then make sure that you choose ports less than port number 49150. Dynamic ports can go up to port number 65535. These ports have to be opened on Siebel Servers. The Siebel system administrator allocates a port to a specific Siebel component. |
Synchronization Manager |
40400 |
None. |
Enterprise Application Integration (EAI) Server |
Allocated by the system administrator. |
None. |
SMTP Mail Server |
25 |
None. |
FTP Port |
21 |
Ports must be opened for the Siebel EAI and Workflow components. The Siebel system administrator allocates these ports. |
Lightweight Directory Access Protocol (LDAP) Server |
389 and 636 |
None. |
Siebel Server or Siebel database |
1521 |
Port 1521 is used for communications between the Siebel Server and Oracle database. |
1433 |
Port 1433 is used for communications between the Siebel Server and Microsoft SQL Server database. |
5000 |
Port 5000 is used for communications between the Siebel Server and IBM DB2 database for Linux, UNIX, and Windows. |
File Server |
139 Transmission Control Protocol (TCP) 137 and 138 User Datagram Protocol (UDP) |
Port numbers for communications between the Siebel Server and the Siebel File System and Database Server are dependent on the file system type. The default TCP port number is 139. The default User Datagram Protocol (UDP) port numbers are 137 and 138. |
Search Server |
2048 |
None. |
