Testing Siebel Business Applications > Usage Pattern Tracking and Conversion to Keyword Scripts > Setting Up DISA > Browser Configuration SettingsThe following table lists the different types of browsers and the supported versions for running the recorded scripts.
To run the recorded scripts in different types of browsers (Chrome, FireFox and Internet Explorer), you must update the browser settings. NOTE: Ensure to disable the "Touch" mode / feature for the targeted browser before proceeding with the automation. To run the recorded scripts using Chrome, download the chromedriver.exe file from https://sites.google.com/a/chromium.org/chromedriver/downloads and copy it to <DISA Installation Location>\DesktopIntSiebelAgent\plugins\SiebelTestAutomation\Drivers location. NOTE: It is recommended to download the driver file after checking the browser version. To run the recorded scripts in Internet Explorer (IE), download the IEdriverserver.exe and copy it to <DISA Installation Location>\DesktopIntSiebelAgent\plugins\SiebelTestAutomation\Drivers location. You must disable the Drag and Drop option, update the Compatibility View settings and Security Settings. To disable the Drag and Drop option
To update the Compatibility View Settings
To update the Security Settings
NOTE: Copy the latest IE Driver "IEDriverServer" from http://www.seleniumhq.org/download/ and place it in the<DISA Installation Location>\DesktopIntSiebelAgent\plugins\SiebelTestAutomation\Drivers folder. Before playing the recorded scripts in the FireFox browser, you must add the Security Exception window in the Location field and add the following address: NOTE: The port 18443 must be changed to the port number which you configured for disa.exe in the config.properties file. |
| Testing Siebel Business Applications | Copyright © 2017, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
