Testing Siebel Business Applications > Usage Pattern Tracking and Conversion to Keyword Scripts > Setting Up DISA > Plugin ConfigurationsAfter installing the Plugin for Siebel Automation with DISA , you must update the unitconfig.xml file. The unitconfig.xml file will be available in the following location: <DISA Installation Location>\DesktopIntSiebelAgent\plugins\SiebelTestAutomation\unitconfig.xml Update the following XML tags under Mandatory_Params
To play the functional flow in Mobile or Simulators.
| Testing Siebel Business Applications | Copyright © 2017, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
