Testing Siebel Business Applications > Usage Pattern Tracking and Conversion to Keyword Scripts > Playing the ScriptsThe scripts that are generated after recording are available in the Scripts Pane. You must download and install DISA (Desktop Integration for Siebel Applications) on the client machine to play the scripts. To play a recorded script from the Scripts Pane:
NOTE: You can play only one script at a time. The Play button will be disabled if you select multiple scripts simultaneously or if there is some issue with the DISA setup.
The play process is initiated in a separate browser window and the results are displayed after the play process is completed. The same script can be played more than once instead of using the replay process. To play a imported or modified script from the Release Screen
The play process is initiated in a separate browser window and the results are displayed after the play process is completed. |
| Testing Siebel Business Applications | Copyright © 2017, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
