Testing Siebel Business Applications > Usage Pattern Tracking and Conversion to Keyword Scripts > Enabling Automation for Developer Web ClientAutomation is available only for Developer Web Clients. Automation is not supported in Mobile Web clients. While installing, you must select the developer web client option only if automation is needed. After installing the Developer Web Client,Tomcat will be automatically deployed in the <webclient install location>\applicationcontainer. The CONTAINERURL for AutomationSubSys section gets updated with the HTTP port provided during the Developer Web Client installation.
#Port number as seen in below section of C:\Siebel\Client\applicationcontainer\conf\server.xml <Connector port="9001" protocol="HTTP/1.1" Playing the script through Developer Web Client is supported. Use the Siebel Thin Client URL to play back the script.
Approach for generating the Script involving switching of users on Portal and consumer applications
NOTE: At this point, since there is a user switch (due to new user login), a anonymous user UPT csv file will be generated in a <anonymous_username> folder under "<SiebelServerBuild>\ses\siebesrvr\UPT" older. Copy this anonymous UPT csv based on timestamp. NOTE: Since the new user has logged out of the application, the new user UPT csv file will be generated in <NewUsername> folder under <SiebelServerBuild>\ses\siebesrvr\UPT" folder.
| Testing Siebel Business Applications | Copyright © 2017, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
