Testing Siebel Business Applications > Usage Pattern Tracking and Conversion to Keyword Scripts >
Setting Up the Automation Adapter
Before you get started with the task of recording a functional flow, you must complete the procedure in this topic to set up the system preferences for Usage Pattern Tracking. To set the system preferences for Usage Pattern Tracking
- Navigate to the Administration - Application screen, then the System Preferences view.
- Set the system preferences in the following table:
Table 10.
Enable UPT |
True |
Enable UPT Context |
True |
UPTMax Record Cache |
100 |
To set the profile configuration parameters for Usage Pattern Tracking
- Navigate to the Administration - Server Configuration screen, then the Enterprises view.
- In the Enterprises Server applet, select the enterprise server you want to configure.
- Click the Profile Configuration tab. Query for the profile AutomationSubSys.
Table 11.
Class Path |
CLASSPATH |
String |
Container URL |
CONTAINERURL |
String |
The value for the jbs CONTAINERURL=http://localhost:<ContainerPort>/siebel/jbs <ContainerPort> value should be taken from file:<Siebel Install Location>\ses\applicationcontainer\conf\server.xml <Connector port="4730" protocol="HTTP/1.1" For Example: http://localhost:4730/siebel/jbs |
To implement the system preferences and profile configuration changes, you must restart the Siebel Gateway and Siebel Services. As an alternate option, you can configure the profile for AutomationSubSys via server manager command:- change param CONTAINERURL=http://localhost:<ContainerPort>/siebel/jbs for named subsystem AutomationSubSys
Table 12. The following table lists the Runtime events configured out of the box.
2 |
Application |
ViewActivated |
KWD |
GetProfileAttr("EnableRecording") = "True" AND GetProfileAttr("RecordingOn") = "True" |
2 |
Application |
ViewDeactivated |
KWD |
2 |
Application |
WebLogin |
KWD |
2 |
Application |
WebLogout |
KWD |
2 |
Applet |
PreInvokeMethod |
KWD |
2 |
Application |
Recording |
KWD |
GetProfileAttr("EnableRecording") = "True" |
2 |
Application |
InvokeServiceMethod |
KWD |
2 |
Application |
UPTClientScript |
KWD |
2 |
Application |
InvokeMethod |
KWD |
NOTE: Any other UPT Events should be disabled or inactivated before using the feature. Please refer to the UPT documentation for Event Details.
