Testing Siebel Business Applications > Usage Pattern Tracking and Conversion to Keyword Scripts > Configuring the UPT and KWD Log Directory for Multiple ServersThis topic provides you with the information on configuring the UPT and KWD log directory for multiple servers. The following procedure shows you how to configure Automation Application Directories in a multiple server or hybrid environment (for example, Microsoft Windows and UNIX). To configure the UPT and KWD log directory In Windows for example, a folder called automation need to be created on the "c:\ drive (c:\automation) and the Siebel Servers are installed in <Siebel Install Location>\ses\siebsrvr. In UNIX for example, a folder called automation mounted as /somepath/automation (which points to the Windows folder)and Siebel Servers are installed under <Siebel Install Location>\ses\siebsrvr.
| Testing Siebel Business Applications | Copyright © 2017, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
