Testing Siebel Business Applications > Usage Pattern Tracking and Conversion to Keyword Scripts >
Recording the Functional Flow
The test automation framework provides the ability to record a functional flow in Siebel using Automation Toolbar. Ensure that the Siebel Application is in the AutoOn mode before recording a functional flow as specified in the following sample URL: https://<URL>:<port>/siebel/app/callcenter/enu?SWECmd=AutoOn. To record a functional flow
- Click the Camcorder on the toolbar to open the recording panel.
- Click Start to record.
- The Camcorder turns red when the recording is in progress.
When you click Pause, the script recording is paused. To resume recording, click Resume.
- Click Stop to end the recording session. The recorded script is generated when you click the Generate button.
The Generate button will be in the enable mode after you click the Stop button.
- Click Scripts on the Toolbar to open the scripts pane. This script pane contains the list of scripts generated.
NOTE: The buttons in the toolbar are enabled or disabled based on the actions that you perform during a recording session. For example, when you click Start, the Pause and Stop buttons are enabled. When you click "Pause" , the "Resume" and "Stop" buttons are enabled. When you click "Stop", the "Start" and "Generate" buttons are enabled.
