Testing Siebel Business Applications > Usage Pattern Tracking and Conversion to Keyword Scripts > Renaming the ScriptsAfter generating the scripts, you can rename the scripts in the script pane. NOTE: You can provide any name to the generated scripts. You can also choose to delete the scripts if that are not required. |
| Testing Siebel Business Applications | Copyright © 2017, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
