Siebel Database Upgrade Guide for DB2 for z/OS > REST API References for Migration Services > Using REST API with the Migration Data Service with Transformation ServiceThe Migration Data Service with Transformation service migrates the data from the source environment to the target environment based on the tables listed in the datamig.inp on the source environment. While exporting the data, this service uses the rule defined in the datamig.rul file and performs the transformation. The transformed data will be migrated to the target environment. Table 28 includes the methods supported for the Migration Data Service with Transformation Service.
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
