Siebel Database Upgrade Guide for DB2 for z/OS > REST API References for Migration Services >
Using REST API with the Migration Schema Service
The Migration Schema Service migrates the physical Siebel schema from the source environment to the target environment. Table 28 includes the methods supported for the Migration Schema Service.
Table 28. Migration Schema Service Supported Methods
Export |
Method used to export a schema for a migration. |
Import |
Method used to import a schema for a migration. |
GetWatermark |
Method used to get a watermark for a migration. |
IsSchemaChanged |
Method used to check if a schema has changed for a migration. |
GetStatus |
Method used to get the status of a migration. |
This topic includes the following topics:
