Siebel Database Upgrade Guide for DB2 for z/OS > REST API References for Migration Services > Using REST API with the Migration Schema Service > Verifying If a Schema Changed with the Migration Schema ServiceYou can check if a schema for a Migration Schema resource has changed by sending an HTTP POST request to the repository resource's URI. The following details are for a request to check if a schema has changed for a resource:
The following are the details for the response to a successful request: |
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
