Siebel Database Upgrade Guide for DB2 for z/OS > REST API References for Migration Services >
Using REST API with the Migration Incremental Runtime Repository Data Service
The Migration Incremental Runtime Repository Data Service identifies the version of the repository data that was previously migrated. This service takes all the changes from the previously migrated version and the latest version and migrates the data to the target environment. Table 28 includes the methods supported for the Migration Incremental Runtime Repository Data Service.
Table 32. Migration Incremental Runtime Repository Data Service Supported Methods
Export |
Method used to export a schema for a migration. |
Import |
Method used to import a schema for a migration. |
GetWatermark |
Method used to get a watermark for a migration. |
DBCheck |
Method used to check a database has for a migration. |
GetStatus |
Method used to get the status of a migration. |
This topic includes the following topics:
