Table 21. Migration Services
Schema Service |
Migrates the physical Siebel schema from the source environment to the target environment. When you use this service, the Siebel Migration prompts you to enter the TableOwner UserName and the TableOwner Password. |
The supported methods for the Schema Service include:
- Export
- Import
- GetWatermark
- IsSchemaChanged
- GetStatus
Design Repository Data Service |
Migrates the design time repository and the runtime repository from the source environment to the target environment. In the target environment, the migrated repository is named Migrated Repository. You must run the Schema Service and the Application Workspace Data Service along with the Design Repository Data Service. After the Siebel Migration is complete, you must change the Migrated Repository to Siebel Repository in the S_REPOSITORY table. |
- Export
- Import
- DBChck
- GetStatus
Runtime Repository Data Service |
Migrates only the runtime repository from the source environment to the target environment. The migrated repository is named Migration Repository in the target environment. The user must select the name and version of the Workspace Branch. The default version will be the latest version. You must run the Schema Service and the Application Workspace Data Service along with the Runtime Repository Data Service. After the Siebel Migration is complete, you must change the Migrated Repository to Siebel Repository in the S_REPOSITORY table. |
- GetRRInfo
- GetWatermark
- Export
- Import
- DBCheck
- GetStatus
Application Workspace Data Service |
Migrates the seed records from the source environment to the target environment. You must run the Schema Service and the Runtime Repository Service along with the Application Workspace Data Service. |
- GetSeedCopyWatermark
- GetFullSeedWatermark
- SeedCopyExport
- GetStatus
- SeedCopyImport
- FullSeedExport
- FullSeedImport
Incremental Runtime Repository Data Service |
Identifies the version of the repository data that was previously migrated. This service takes all the changes from the previously migrated version and the latest version and migrates the data to the target environment. You must run the Schema Service along with the Incremental Runtime Repository Data Service. The Schema Service only runs if there is a change detected as part of the incremental migration. Otherwise, the Schema Service will not run even though it is part of the selection. |
- Export
- Import
- GetWatermark
- DBCheck
- GetStatus
Incremental Application Workspace Data Service |
Identifies the version that was previously migrated. This service takes all the changes from the previously migrated version to the latest version and migrates them to the target environment. |
- GetWatermark
- Export
- Import
- GetStatus
Application Data Service |
This service migrates the data from the source environment to the target environment based on the tables listed in datamig.inp file on the source environment. |
Application Data Service With Transformation |
Migrates the data from the source environment to the target environment based on the tables listed in the datamig.inp on the source environment. While exporting the data, this service uses the rule defined in the datamig.rul file and performs the transformation. The transformed data will be migrated to the target environment. |
File Prepare And Deploy Service |
Identifies all the new or modified files and migrates the files to the target environment. On the target environment, the File Prepare And Deploy Service transfers the modified or new files to each Siebel Application Interface node defined in Siebel Management Console (SMC). This service keeps track of the files that are migrated for each target environment. The next time that the user runs this service, the service will check the modified files or newly created files from the previous migration. This service migrates the file artifacts from Siebel Application Interface and the file system. |
