Siebel Database Upgrade Guide for DB2 for z/OS > Migrating Data for a Dev to Test to Production with Siebel Migration > Process of Using Siebel Migration to Migrate Data > Executing a Siebel Migration PlanThis procedure describes how use Siebel Migration to execute a migration plan for a migration. This task is a step in Process of Using Siebel Migration to Migrate Data.
NOTE: If the Schema Service is part of the Migration Plan, the application will prompt you for Target Database Schema Owner credentials. |
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
