Siebel Database Upgrade Guide for DB2 for z/OS > Migrating Data for a Dev to Test to Production with Siebel Migration > Process of Using Siebel Migration to Migrate Data > Creating a Migration PlanWhen you create a Migration Plan, you must select connections, including the source environment and the target environment. When you run the Migration Plan, Siebel Migration exports the migration data from the Source environment and imports it into the Target environment. When you create the Migration plan, you must select the resources that you want to migrate as part of this migration plan. In Siebel Migration, you can select Database Utilities, ADM Projects or File Prepare and Deploy services. This procedure describes how use Siebel Migration to create a migration plan for a migration. This task is a step in Process of Using Siebel Migration to Migrate Data.
Siebel Migration Plan DependenciesThe Siebel Migration Discovery services that appear in Siebel Migration depends on selections that you make. Table 22 contains Siebel Migration plan dependencies.
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
