Using Siebel Tools > Using Siebel Tools > Using Windows, Wizards, and Toolbars >
Using Web Templates
Web Template is an applet in Web Tools that displays the HTML code of a Siebel Web Template in an editor and also lets you preview the object design. To use the Web Templates applet
- In Web Tools, navigate to Object Explorer and then click the Web Template object.
To filter the templates, you can use the filter preceding the list of objects or run a query using the gear icon in the Object List Editor applet.
- Drill down on the Web template that you want to view or modify.
Web Tools displays the HTML code for Siebel Web Template in Object List Editor. To modify, you must first open a workspace. To do so, see To access and open the Workspace Dashboard view in the Web Tools mode.
- If the Web template is editable, you can edit the HTML code in the editor.
You can customize the editor with options such as auto-close tags, hints, display of line numbers or Object Design hierarchy, and indentation. The settings you select are automatically available whenever you access the editor.
- Click the Preview (eye-shaped) icon to preview the object design.
You can toggle between the editor and preview.
- Click the Back button to exit the preview.
NOTE: To learn more about layout editors, see Using a Layout Editor.
