Using Siebel Tools > Using Siebel Tools > Using Windows, Wizards, and Toolbars >
Using the Toolbars
Figure 3 illustrates the toolbars that you can use in Siebel Tools. A toolbar is active only if the object type or window that uses it is active. You can relocate toolbars using the mouse. You can display and hide toolbars.
Figure 3. Toolbars You Can Use in Siebel Tools
Explanation of Callouts
Siebel Tools includes the following toolbars:
- Edit Toolbar. Allows you to use edit tools, the New Object wizard, and undo and redo options. You can right-click a field in the Object List Editor to display a menu of edit tools. For more information, see Using a Layout Editor.
- List Toolbar. Allows you to insert a new record, move forward and backward through records, query records, and sort records. It manages records that the Object List Editor shows.
- History Toolbar. Allows you to retrace your steps, and to create and navigate to bookmarks.
- Debug Toolbar. Allows you to access debug tools that you can use with Siebel VB and Siebel eScript. For more information, see Using Siebel Script Editors.
- Simulate Toolbar. Allows you to simulate a workflow process.
- Format Toolbar. Allows you to apply a format to an applet control. This control uses a Web template that uses a grid layout.
- WF/Task Editor Toolbar. Allows you to publish, revise, or expire a workflow process or task UI. You can activate a workflow process if you are the owner of the root workspace and the workflow is delivered into it.
- Configuration Context Toolbar. Allows you to define settings for Web browser layout and scripting.
Displaying a Toolbar
You can display a toolbar. To display a toolbar
Displaying the Status Bar
You can display the status bar. To display the status bar
