Using Siebel Tools > Using Web Tools >
Siebel Tools Objects Included in Web Tools
Table 5 shows the objects in Siebel Tools that Web Tools currently supports. CAUTION: Operations are not allowed on the read-only objects: Dock Object, the Schema Maintenance objects, Task, Type, Repository, Table, and EIM Interface Table.
Table 5. Objects in Siebel Tools That Web Tools Supports
Applet |
Find |
Screen |
Workflow Process |
Application |
HTML Hierarchy Bitmap |
Symbolic String |
Business Component |
Icon Map |
System Activity Object |
Assignment Attribute |
Import Object |
Table |
Assignment Criteria |
Integration Object |
Task |
Bitmap Category |
Link |
Task Group |
Business Object |
Menu |
Toolbar |
Business Service |
Message Category |
Type |
Class |
Pick List |
View |
Command |
Project |
Web Page |
Content Object |
Repository |
Web Template |
DLL |
Schema Maintenance Phase |
Workflow Policy Column |
Dock Object |
Schema Maintenance Process |
Workflow Policy Object |
EIM Interface Table |
Schema Maintenance Step |
Workflow Policy Program |
