22406 - Routing attempt failed due to internal resource
exhaustion
- Event Type:
- RBAR
- Description:
- A message could not be routed because the internal
"Request Message Queue" to the
DSR
Relay Agent was full. This should not occur unless the MP is experiencing local
congestion as indicated by Alarm-ID
22200 - MP CPU Congested.
- Severity:
- Info
- Instance:
- <MPName>
- HA Score:
- Normal
- Throttle Seconds:
- 10
- OID:
- eagleXgDiameterRbarRoutingAttemptFailureInternalResExhNotify
Recovery:
If this problem occurs, it is recommended to contact
My Oracle Support (MOS).
