Go to primary content
Diameter Signaling Router Alarms and KPIs
Release 8.2
E89015-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
22405 - Valid address received didn’t match a provisioned address or address range
Event Type:
RBAR
Description:
A message could not be routed because a valid address was found that did not match an individual address or address range associated with the Application ID, Command Code, and Routing Entity Type, and the Routing Exception was configured to send an Answer response.
Severity:
Info
Instance:
<AddressResolution>
HA Score:
Normal
Throttle Seconds:
10
OID:
eagleXgDiameterRbarAddrMismatchWithProvisionedAddressNotify
Recovery:
  1. An individual address or address range associated with the Application ID, Command Code and Routing Entity Type may be missing from the RBAR configuration. Validate which address and address range tables are associated with the Application ID, Command Code and Routing Entity Type.
  2. View the currently provisioned Application IDs, Command Codes, and Routing Entity Types by selecting RBAR > Configuration > Address Resolutions.
