Go to primary content
Diameter Signaling Router Alarms and KPIs
Release 8.2
E89015-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
22729 - PCRF Not Configured
Alarm Group:
PCA
Description:
PCRF Not Configured
Severity:
Major
Instance:
Policy Binding Region Place Association Name
HA Score:
Normal
Auto Clear Seconds:
0 (zero)
OID:
pdraPcrfNotConfiguredNotify
Recovery:
  1. Check the NOAM GUI at Policy and Charging > Configuration > Policy DRA for further PCRF configuration.
  2. Check the event history logs in Alarms & Events.
  3. If the problem persists, it is recommended to contact My Oracle Support (MOS).
