Go to primary content
Diameter Signaling Router Diameter User's Guide
Release 8.2
E88998
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Diameter S9 PCRF Topology Hiding Configuration Set elements
Table 10-21 describes the fields on the S9 PCRF Topology Hiding Configuration Sets View, Edit, and Insert pages. Data Input Notes apply only to the Insert and Edit pages; the View page is read-only.
Table 10-21 S9 PCRF Topology Hiding Configuration Sets Elements
Field (* indicates required field) Description Data Input Notes
* S9 PCRF Topology Hiding Configuration Set Name A name that uniquely identifies the S9 PCRF Topology Hiding Configuration Set.
Format: case-sensitive string; alphanumeric and underscore (_); must contain at least one alpha and cannot start with a digit
Range: 1 - 32 characters
Pseudo Hostname Generation
Attributes to control the format and generation of Pseudo Hostnames corresponding to an Actual Hostname.
  • Count - The maximum number of Pseudo Hostnames associated with an Actual Hostname.
  • Randomize Count - If checked, random number of Pseudo Hostnames between 1 and Count are associated with an Actual Hostname.
  • Auto Generate - If checked, Pseudo Hostnames are automatically generated corresponding to an Actual Hostname.
  • Prefix - Prefix for the auto generated Pseudo Hostname. Prefix is a case-insensitive string consisting of a list of labels separated by dots, where a label may contain letters, digits, dashes (-) and underscore (_). A label must start with a letter, digit or underscore and must end with a letter or digit. Underscores may be used only as the first character. Prefix must be at most 63 characters long.
  • Suffix - Suffix for the auto generated Pseudo Hostname. Suffix is case-insensitive string consisting of a list of labels separated by dots, where a label may contain letters, digits, dashes (-) and underscore (_). A label must start with a letter, digit or underscore and must end with a letter or digit. Underscores may be used only as the first character. Suffix must be at most 63 characters long.
  • Length - Length of the random number used in the auto generated Pseudo Hostname.
Count:
  • Default = 3
  • Range = 1 - 3
Randomize Count:
  • Default = Checked
  • Range = n/a
Auto Generate:
  • Default = Checked
  • Range = n/a
Prefix:
  • Default = n/a
  • Range = A valid Prefix
Suffix:
  • Default = n/a
  • Range = A valid Suffix
Length:
  • Default = 4
  • Range = 4 - 5
* Hostnames List of Actual Hostnames and their Pseudo Hostnames in this S9 PCRF Topology Hiding Configuration Set.
Format: case-insensitive string consisting of a list of labels separated by dots, where a label may contain letters, digits, dashes (-), and underscore (_). A label must start with a letter, digit, or underscore and must end with a letter or digit. Underscores can be used only as the first character.
Label - up to 63 characters; S9 PCRF Pseudo Hostname - up to 255 characters.
S9 PCRF Actual Hostname Not Found Action Action to be performed when the Orig-Host in the Diameter message is not configured as Actual Hostname in this S9 PCRF Topology Hiding Configuration Set.
Default: Send Answer
Range: n/a
S9 PCRF Actual Hostname Not Found Answer Result-Code Value Value to be placed in the Result-Code AVP of the Answer message. S9 PCRF Actual Hostname Not Found Answer Result-Code Value is required if action is Send Answer.
Default: 3002
Range: 1000 - 5999
S9 PCRF Actual Hostname Not Found Vendor ID Vendor ID is placed in Vendor ID AVP
Default: n/a
Range: 1 - 4294967295
S9 PCRF Actual Hostname Not Found Answer Error Message String to be placed in the Error-Message AVP of the Answer message
Default: null string, no Error-Message AVP in Answer message
Range: 0 - 64 characters
