Go to primary content
Diameter Signaling Router Policy and Charging Application
Release 8.2
E89000
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Congestion Options
Congestion Options are configurable on Active NOAM servers.
The Congestion Options can be configured:
  • Alarm Thresholds, which are used to:
    • Set the percentage of the Policy and Charging ingress message rate capacity at which an alarm is raised with Critical, Major, or Minor severity.
    • Set the percentage of the Policy and Charging ingress message rate capacity at which a Critical, Major, or Minor severity alarm is cleared.
    The percentages control the onset and abatement of the corresponding Congestion Levels.
    Default thresholds are based n the engineered system value for Ingress Policy and Charging Request Message Capacity.
  • Message Throttling Rules, which determine the percentage of Session Creation, Update, and Terminate Request messages that are discarded when Congestion Levels 1, 2, and 3 exist.
The fields are described in Congestion Options elements.
