Go to primary content
Diameter Signaling Router Policy and Charging Application
Release 8.2
E89000
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Defining Alarm Settings
Use this task to define Alarm Settings on an Active NOAM.
Alarm Settings are configurable only on Active NOAM servers, and are viewable on NOAM and SOAM servers.
The fields are described in Alarm Settings elements.
  1. Click Policy and Charging > Configuration > Alarm Settings.
    The Policy and Charging > Configuration > Alarm Settings page appears.
  2. Enter values in the editable fields to define the alarm settings.
  3. Click:
    • Apply to save the changes and remain on this page.
    • Cancel to discard the changes and remain on the Policy and Charging > Configuration > Alarm Settings page.
    If Apply is clicked and any of several conditions exist, an error message appears:
    • The entered values contain the wrong data type or is out of the allowed range.
    • The value entered for Critical Alarm Threshold (Percent) is less than or equal to the value entered for Major Alarm Threshold (Percent).
    • The value entered for Major Alarm Threshold (Percent) is less than or equal to the value entered for Minor Alarm Threshold (Percent).
