Table 6-13 describes the elements on the page.
Table 6-13 Binding Key Priority Elements
| Field (* indicates a requried field) | Description | Data Input Notes |
| * Binding Key Type | The Binding Key Type which is assigned to a Binding Key Priority. Note: The first row is Priority 1 and the corresponding Binding Key Type is IMSI. This row is read-only. |
Format: Pulldown list Range: MSISDN, IPv4, or IPv6 for Priority 2, 3, and 4 Default: -Select- (No Binding Key Type selected) |
