Go to primary content
Diameter Signaling Router Roaming Steering
Release 8.2
E89014
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Adding a new SoR_Profile entry
Use this task to add SoR provisioning entries.
  1. Navigate to DCA Framework > DCA Roaming Steering > Application Control.
  2. Select DCA_SOR.
  3. Select a Version Name.
  4. Select a Config Tables and Data.
  5. Select a Table Name.
  6. Select a Provision Table.
  7. Fill out the fields to define the table. The field values you provide define either Config_Params or SoR_Profile configuration parameters (this depends on which provision option that you selected).
