Go to primary content
Diameter Signaling Router Roaming Steering
Release 8.2
E89014
Contents
Previous
Next
Configuring SoR Provisioning Tables
Use this task to configure SoR provisioning tables.
The available GUI choices differ between the SO and the NO.
The fields are described in
Table 4-3
and
Table 4-4
Select
DCA Framework
Roaming of Steering
Application Control
Select a
Version Name
choice.
Click the appropriate action button; for example,
Config Tables and Data
on the NO or
Config Data
on the SO.
Select a
Table Name
Select
Provision Table
Fill out the fields to define or edit the selected table.
Click
OK
or
Apply
to complete the task.
