Go to primary content
Diameter Signaling Router Roaming Steering
Release 8.2
E89014
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Page Controls
User interface pages contain controls, such as buttons and links, that perform specified functions. The functions are described by the text of the links and buttons.
Disabled buttons are grayed out. Buttons that are irrelevant to the selection or current system state, or which represent unauthorized actions as defined in Group Administration, are disabled. For example, Delete is disabled for users without Global Data Delete permission. Buttons are also disabled if, for example, multiple servers are selected for an action that can only be performed on a single server at a time.
Table 2-4 contains examples of Action buttons.
Table 2-4 Example Action Buttons
Action Button Function
Insert Inserts data into a table.
Edit Edits data within a table.
Delete Deletes data from table.
Change Changes the status of a managed object.
Some Action buttons take you to another page.
Submit buttons, described in Table 2-5, are used to submit information to the server. The buttons are located in the page area and accompanied by a table in which you can enter information. The Submit buttons, except for Cancel, are disabled until you enter some data or select a value for all mandatory fields.
Table 2-5 Submit Buttons
Submit Button Function
OK Submits the information to the server, and if successful, returns to the View page for that table.
Apply Submits the information to the server, and if successful, remains on the current page so that you can enter additional data.
Cancel Returns to the View page for the table without submitting any information to the server.
