Searching the Audit Log
- Expand the Security Manager slider and select Audit log > View.
- In the Audit log pane, select an entry row in the table and click Search.
In the
Audit Log Search dialog box, complete some or all of the following fields to search the audit log:
Name Description Username field Choose the name of the user who performed the operation. Category drop-down list Choose the category of operation performed by the user. For example, Authentication. Operation box Chose the specific operation performed by the user. Management Server The IP address of the management server accessed. Client IP The IP address of the client that was used. Device The name of the device that the user performed an operation upon. Status The status of the operation performed by the user, whether it was successful or failed. Start Time Choose a start time from the calendar. End Time Choose an end time from the calendar. - Click OK.
