Configuring Severity Color Coding
- On the main menu, click
- In the Alarm colors dialog box, click the Color drop-down list next to the severity category and its default color.
- In the pop-up color palette, click the new color that you want for the alarm.
- Repeat the previous two steps if you want to configure more severity alarm colors.
- Click OK.
- In the success Information dialog box, click OK.
