Enable and Configure Audible Alarms
- On the main menu, click Settings > Alarms > Audible Alarms
- In the Audible Alarms dialog box, click the check box next to the severity categories that you want to enable an audible alarm. The categories are Emergency, Critical, Major, Minor, and Warning.
- Click OK.
- On the Oracle Communications Session Delivery Manager navigation bar, select Fault Manager > Alarms
Click
Start Audible Alarm.
The button toggles to Stop Audible Alarm.
If you want to shut down the audible alarms application, click
Stop Audible Alarm.
The button toggles to Start Audible Alarm.
