Audible Alarms
The audible alarms system allows you to set off an audible sound when an activated alarm is triggered.
Alarm events are updated during each refresh cycle of the alarms table. Search functionality is disabled when audible alarms are active. The audible alarms cease to function upon exiting the Fault Manager navigation bar slider.
Audio Files
The Audible Alarms application comes with five alarm sounds (one for each severity). You may replace these files with your own files as long as the files retain the same filenames and are in a Waveform audio file format. The files are located in the following directory:
<installed directory>\ACMEConsole\audibleAlarms
The filenames appear as:
- Audio_Emergency.wav
- Audio_Critical.wav
- Audio_Major.wav
- Audio_Minor.wav
- Audio_Warning.wav
