Remapping Alarm Severities
- Expand the Fault Manager slider and select Trap event setting.
In the
Select dialog box, select from the following alarm trap groups from the
Trap Groups table:
Oracle Communications Session Delivery Manager determines the trap groups that you can access.- AcmeSD—Session Delivery plugin trap group.
- SDM—Default Oracle Communications Session Delivery Manager trap group.
- In the Trap Event Mapping Console pane, select a trap from the SNMP Trap OIDs table.
- In the Severity Mapping table, select a severity cell from the Current severity column for a trap condition row that you want to modify.
In the drop-down list of severity levels that appears, click the severity level that you want to apply.
The Default severity column serves as a reference point and continues to show the default severity setting for the trap condition.The new level appears in the Current Severity column for the trap condition. - Click Apply.
- In the success dialog box, click OK.
