Clearing Alarms
The appropriate administrator privileges must be assigned to clear alarms.
Clearing an alarm in Oracle Communications Session Delivery Manager has no affect on the node because the node is unaware that Oracle Communications Session Delivery Manager displayed the alarm or changed its severity to clear.- Expand the Fault Manager slider and select Alarms.
- In the alarms table, select the alarm that you want to clear and click Clear.
- In the Clear dialog box, click Yes.
- In the Info dialog box, click OK.
