Unacknowledging Alarms
The appropriate administrator privileges must be assigned to unacknowledge alarms.
- Expand the Fault Manager slider and select Alarms.
- In the alarms table, select the alarm that you want to unacknowledge and click Unacknowledge. The Acknowledge dialog box appears.
- In the Unacknowledge dialog box, click Yes.
- In the Info dialog box, click OK.
