Acknowledging Alarms
The appropriate administrator privileges must be assigned to acknowledge alarms.
- Expand the Fault Manager slider and select Alarms.
- In the alarms table, select the alarm that you want to acknowledge and click Acknowledge.
- In the Acknowledge dialog box, click Yes.
- In the Info dialog box, click OK.
- Click the alarm to view an updated Alarm detail dialog box with the Acknowledged by and Last modified fields updated.
- Click OK.
